hello, this is my system:
GA-EP45-DS3
E8400
2 x DDR2-SDRAM 1000Mhz (PC2-8000) (F2-8000CL5-2GBPQ)
my problem is, that the memory only runs on 800 mhz instead of 1000 as it should be.
what have i to do to solve the problem? my knowledge about bios settings isn't very good
the bios version is F4. do i have to upgrade it, so that the motherboard will automatically detect the memory with 1000 mhz?
and the dram voltage was automatically set to 1,8v, do i have to change it`?
here are some details by cpuz:
thx for your help
GA-EP45-DS3
E8400
thx for your help
