F2-8800CL5D-4GBPI how to configure GA-G41M-ES2L
  • F2-8800CL5D-4GBPI how to configure GA-G41M-ES2L
    please!
    how to configure the Bios of Gigabyte GA-G41M-ES2L with F2-8800CL5D-4GBPI
    What CPU?
    Generally CPU FSB 1500, with memory at 1100 is a good ratio.
    Check DRAM Frequency to see which options you have, then raise CPU FSB if needed to achieve DDR2-1100. Don't forget to set timings and voltage.
      my cpu is a e2160 but I'll change for an E8500 within a short time
      if i set a System Memory Multiplier AS 3.33... i get a blue scren
      if set a performance Enhance anyone is all the same
      in dram voltage can set 1,8 1.9 2,0 but set in auto i can look in pc is set a 1.920
        Nothing anymore?
          Of course, your CPU Host Frequency is overclocked from 200 to 330, and all your voltages are AUTO. NO way that will work.
          Try this:
          CPU Host Frequency - 266
          System Memory Multiplier - 4.00A
          DRAM Voltage - 1.90V
          Timings are fine like in your pictures.
          Then see how that works.
