Benchmarking with MaxxMem2 shows memory score 7.3 GB/s.
Memory score seems approximately 14% below the expected 8.5 GB/s
for a single channel. But this is a dual channel setup, so
was expecting a memory score of 9 GB/s or more.
(I was expecting more because I have an older PC with dual channel
PC3200 and it gets a memory score of 4.36 GB/s - that's 36% greater
than the expected rate for single channel PC3200)
Can you please explain why the GSkill F2-8500CL5D-2GBPK memory score
is low?
System board: GIGA-BYTE GA-EP45-UD3L
Latest BIOS F9
BIOS set with factory defaults
Processor : Intel Core 2 Duo E8400
Memory : 4GB = 2 F2-8500CL5D-2GBPK (4 1GB sticks - dual channel)
CPUZ shows : FSB 333.7 MHz
Memory Frequency 533.9 MHz
Thank you.
is low?
Latest BIOS F9
Thank you.
