I bought 2 kits of 2 x F2-8800CL5-2GBPI (two different kits, so the four sticks are probably not matched), in the late summer of 2010. However, since I installed these modules I keep getting BSODs once in a while (Windows 7, x64) - I assumed it was mainly due to an old installation of Windows. Hence I re-installed Windows this week (I know it is late, but I didn't not prioritize it before). But I keep getting these BSODs.
Before the G. Skills, I've used some Crucial Ballistix (PC2-8500, 4 x 1GB), and these didn't give me BSODs. But two of these sticks died, so during the following replacement I wanted more and faster RAM. And that's why I choose the G. Skill.
My specs are listed below:
CPU: Intel Q9450 @ stock speed (2.66 Hz), WC
MB: Asus P5E WS Pro, bios 1203 (the newest)
RAM: 4 modules of F2-8800CL5-2GBPI
GFX: Radeon HD3870
OS SSD: Intel X25-M -G2, 80GB
SAS RAID card: LSI Logic MegaRAID 9260-8i
Storage HDDs: 4 x WD RE3 1TB in RAID-5
More information regarding DDR2:
FSB/DRAM ratio: 5:8
Memory Speed: 534,3 MHz
Size: 4 x 2048 MB
Dual Channel Mode
Timings:
CAS# Latency (CL): 5
RAS# to CAS# Read Delay (tRCD): 5
RAS# to CAS# Write Delay: 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 15
Other Timings:
All Precharge to Activate: 6 (greyed out in MemSet 4.1)
Refresh Cycle Time (tRFC): 68
Performance Level: 8
Write to Precharge Delayed: 21
Write to Read Delay (tWTR): 12
Act. to Act. Delayed (tRRD): 4
Read to Write Delay (tRD_WR): 8
Read to Precharge (tRTP): 6
All Precharge to Refresh Delay: 6 (greyed out in MemSet 4.1)
Refresh Period (tREF): 3120T
Command Rate (CR): 2T
All timings are read by MemSet 4.1, and left at auto in the bios. Tried to configure it manually (5-5-5-15 @ 1066 MHz), but the instability increased. Yesterday, I ran MemTest86+ (v. 4.10) for 1 pass (~58 min), where 1837 errors were encountered! The program halted at 58 min, and did not continue (computer was then shutdown).
Can someone help me to get these modules stable, preferably at 1100 MHz (using another FSB/DRAM ratio - would be great if I could OC the CPU some as well)?
If You need more information and/or I should do additional testing, please don't hesitate to ask.
GFX: Radeon HD3870
FSB/DRAM ratio: 5:8
Size: 4 x 2048 MB
Dual Channel Mode
Timings:
Other Timings:
