memory upgrade with abit ip35 pro
  • memory upgrade with abit ip35 pro
    Checking to see if gskill memory will work with board and config. shown below. Trying to goto windows 7 64bit, from 32bit windows xp, would like to go to either 4gb or 8gb memory using this kit
    G.SKILL F2-6400CL4D-4GBPI-B
    OCZ GameXStream OCZ600GXSSLI 600W ATX12V SLI Certified CrossFire Ready Active PFC Power
    Supply
    ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard
    Intel Core 2 Duo E6850 Conroe 3.0GHz LGA 775 65W Dual-Core Processor BX80557E6850
    sased
    post gskill will memory work with this board and config. going to windows 7 64bit, from
    32bit windows xp, would like to go to 8gb memory
    No problems going with either the 4Gb or 8Gb of that memory. Good stuff and works great on Abit IP35 Pro (in fact did a motherboard review on another site with that same board and RAM).
    MSI Big Bang xPower x58
    Intel i7 950
    GSkill DDR3 2000 6x2Gb
    Gigabyte GTX 460 x2 SLi
    OCZ Vertex 2 SSD - OS Drive
    Corsair TX950W
      Thanks for the reply. Link to your review would be great. Any gotcha on setting up the new memory.
      Thanks again
      sased
        No gotcha setting up the memory.
        Can't provide a link because website was sold to OCC and reviews didn't transfer over.
        Intel i7 950
        Corsair TX950W
