I've been running 2GB of these for the last three years and they've been rock solid, but I decided to upgrade to 4GB so I purchased another set. However, after I inserted them, my monitor had no signal when I booted the computer back up again. I checked and rechecked all connections, they were all tight, but still no signal. Here is everything I've tried with no luck:
- Removing the new RAM and leaving the original sticks
- Trying just the new RAM
- Rearranging the RAM in different slots
- Swapping in a different video card
- Swapping in a different power supply
- Swapping in a different hard drive
The only conclusion I can draw from this is that one or both of the new sticks were faulty which caused my motherboard to short out. If that is indeed the case, is there anything regarding the replacement of components that have been rendered inoperable by a faulty GSkill product? Any insight into this matter would be greatly appreciated. Thank you.
Mobo: Gigabyte GA-M57 SLI-S4
RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel x2
OS: Win 7 Ultimate 64 bit
Vid card: Nvidia GeForce 8600 GTS 256MB
Hard drives: HITACHI 0A38016 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive, Seagate Barracuda 7200.10 ST3320620AS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive (Perpendicular Recording Technology)
Processor: AMD Athlon 64 X2 5200+ Windsor 2.6GHz Socket AM2 89W Dual-Core
Power supply: FSP Group Blue Storm II 500W ATX 2.2 SLI Ready Active PFC Power Supply compatible with Core i7
Optical drive: NEC DVD Burner Black IDE Model ND-2510A
