Bizzare happenings with 2 sets of F2-8500CL5D-2GBPK.
  • Bizzare happenings with 2 sets of F2-8500CL5D-2GBPK.
    First off, here's my hardware.
    Motherboard : GA-EP45-DS3L
    CPU: Intel Core 2 E8500
    Video: EVGA GeForce GTX260
    OS: Windows 7 Ultimate 64-bit
    I originally built this machine a few years ago, and last week I ordered another 2x1GB set of RAM for it. The model numbers are the same, but the heatsinks look a little different. I'm not sure whether or not this matters, and whether there may be some issue between the new set and the old set. Now here's my problem. The old set works fine. The new set works fine. Each individual stick is fine. But when I put them together, I get some very strange issues. If the old pair are in the first set of slots and the new pair in the second set Windows says I have 4GB installed but only 1 available. The BIOS and memtest list 1537MB as being available, which makes no sense, and memtest fails every time. If I put the new pair in the first slots and the old pair in the second slots, the machine won't even POST.
    The board is supposed to support up to 16GB, so I don't believe I'm hitting any board limit. I have updated the BIOS, first to the latest stable version, then to the newest beta as well. I've set the timing manually to 5-5-5-15 according to the sticker on the RAM. The voltage is listed as 2.0-2.1, so I set it to 2.0 since I wasn't sure. I thought about testing it on another board, unfortunately I don't have any others with 4 slots of DDR2.
    I've had good luck with GSkill RAM in the past, but I'm at a bit of a loss here. I don't know if it's a problem with the new RAM, the mixing of old and new RAM, some strange issue with the board, or something else. Any ideas?
    DRAM Voltage should be 2.10V
    With 4 sticks, MCH Core Voltage should be 1.40V.
    I would suggest try other memory in the system to see if they detect incorrectly as well. May be a problem with the motherboard.
      Thanks for your reply.
      I tried adjusting the voltages, but it did not fix the problem. The only other DDR2 I have are simple generic sticks that came with a prebuilt PC, but they do work correctly. I called GSkill tech support on the phone and they recommended I ship all 4 sticks back for replacement. I will do so, and post the results in this topic when I get the new RAM.
        I just got the new RAM today and it seems to work fine. Passes memtest and shows up as the full 4GB. Thanks for the replacement GSkill.
          Glad to hear the new kits work together.
