F2-6400PHU1-1GBNR Won't post
  • F2-6400PHU1-1GBNR Won't post
    Hi:
    I have a new build with an
    Asus m4a785-m mobo bios dated March 2010
    athlon II x4 635
    Win XP sp 3
    I have 4 1gb sticks of f2-6400phu1 - 1gbnr ram from 2 computers that I am trying to install into this 1.
    When I put all 4 in it won't post. it will recognize all individually but i can only boot and run 2 sticks in dimm a1 + a2 slots. also, they will run in single channel only in this configuration.
    What settings do I have to change to make all 4 sticks run together in dual channel mode?
    Any help is greatly appreciated.
    Have you tried A1+B1 slots? Can two sticks work in dual channel? If not, the motherboard may be defective. If no problem, then you may need to raise VDDNB Voltage +0.1V and HT Voltage to 1.30V-1.40V to stabilize four modules.
      Yes I did try, these are the only 2 slots that work.
