Maximus Formula BIOS 1403 made system unstable
  • Maximus Formula BIOS 1403 made system unstable
    Since updating BIOS on Maximus Formula to 1403 reboots result in BSOD and ASUS support told me to ask you for the timings to run this memory on this board. F2-8500CL5D-4GBPK PC2-8500 DDR2-1066 CL5-5-5-15 240PIN Dual Channel. If I run at these timings I get random BSODs as well.
    Below are crash reports.
    Dump File : Mini071410-01.dmp
    Crash Time : 7/14/2010 10:36:44 AM
    Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
    Bug Check Code : 0x1000008e
    Parameter 1 : 0xc0000005
    Parameter 2 : 0x89e2a11c
    Parameter 3 : 0xb47928e4
    Parameter 4 : 0x00000000
    Caused By Driver : win32k.sys
    Caused By Address : win32k.sys+10db
    File Description : Multi-User Win32 Driver
    Product Name : Microsoft? Windows? Operating System
    Company : Microsoft Corporation
    File Version : 5.1.2600.5976 (xpsp_sp3_gdr.100501-1623)
    Processor : 32-bit
    Computer Name :
    Full Path : C:\WINDOWS\Minidump\Mini071410-01.dmp
    Processors Count : 2
    Major Version : 15
    Minor Version : 2600
    Dump File : Mini071410-02.dmp
    Crash Time : 7/14/2010 10:38:35 AM
    Bug Check String : ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
    Bug Check Code : 0x000000fc
    Parameter 1 : 0xb4371700
    Parameter 2 : 0x58541963
    Parameter 3 : 0xb43713ec
    Parameter 4 : 0x00000001
    Caused By Driver : ntoskrnl.exe
    Caused By Address : ntoskrnl.exe+22f43
    File Description : NT Kernel & System
    File Version : 5.1.2600.5938 (xpsp_sp3_gdr.100216-1514)
    Processor : 32-bit
    Computer Name :
    Full Path : C:\WINDOWS\Minidump\Mini071410-02.dmp
    Major Version : 15
    Dump File : Mini071910-01.dmp
    Crash Time : 7/19/2010 12:14:57 PM
    Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
    Bug Check Code : 0x100000d1
    Parameter 1 : 0xdeadfad6
    Parameter 2 : 0x00000002
    Parameter 3 : 0x00000000
    Parameter 4 : 0xb83832b5
    Caused By Driver : usbuhci.sys
    Caused By Address : usbuhci.sys+32b5
    File Description : UHCI USB Miniport Driver
    File Version : 5.1.2600.5512 (xpsp.080413-2108)
    Processor : 32-bit
    Computer Name :
    Full Path : C:\WINDOWS\Minidump\Mini071910-01.dmp
    Major Version : 15
    Did you increase the DRAM Voltage? Try testing each stick individually.
