register
Make sure you have the latest BIOS. Then try these settings:
CPU Host Clock Control - Enabled
CPU Host Frequency - 333
System Memory Mulitplier - 3.20B
CAS Latency - 5
tRCD - 5
tRP - 5
tRAS - 15
