My bios settings have reset and I can't find again the sub-timings needed for those memory. There was a nice bios screenshot for those, but it's not available anymore. (was hosted on gskillusa). I'm getting some BSOD since that bios settings reset.
I've read the sticky and found :
Right now i'm using 4-4-4-12-4-42-3-11-7-13 but there are many more options to fit the 4-42-3-11-7-13 thus i don't really know where to put what. In the quote above i can't find the "42" and in my bios i can only set it to 40 or 45.
Anyone could be kind enough to be really precise and tell me what timings and subtimings to use with those settings. I'm running the FSB at 400Mhz, and the RAM is 1:1. I'm running an Asus P5QC and here are the timings i have using memset.
CL4-4-4-12 / CL4-4-3-10(2 sticks)/14(4 Sticks) *Recommended to those who has locked multiplier with FSB at/above 450Mhz*:
-Up to: 938Mhz/1002Mhz (depending ratio 1:1 938Mhz / 5:6 1002Mhz)
-tRP 3t-above (without errors didn't see any reason why not use 3t condition +920Mhz 1:1 4T).
-tRAS 10t-above (with 8GB to consider 14 or 17t seems the best).
-tWR=6t-8t, tWTR: S=3t D=4t(5T at +920Mhz), tRTR S=4t D=5t, tWTW: S=4t D=5t, tRTW=7t
-Performance level/tRD: Read 'Enable Static read' + Auto Performance Level
-'ALL PRE Delay to XXX' HAS to be 4T min. tWTP to be (ALL PRE Delay to XXX + Pre to Pre + RTP = tWTP) = 12 at tRTP at 3T (tRTP would be faster at maximum(15T)).
-Voltages: Functional at 1.86v(BIOS, 1.960v Actual), Recommended: 2.160v (ASUS boards = 2.06v, Gigabyte = 1.90v.. on BIOS)
