Gigabyte MA790X-UD3P and F2-6400CL4D-4GBPI-B
  • Gigabyte MA790X-UD3P and F2-6400CL4D-4GBPI-B
    Hello guys, I'm having some issues/instability when my RAM is above 900MHz.
    I just did a testing and, I booted my FSB with 224 and Memory x4.00 (= 896MHz) and ran memtest and ORTHOS, it was stable, then I just pushed to 225 and Memory x4.00 (= 900 MHz) and it was a NO GO, unstable.
    And my point is, I bought this new motherboard just to overclock my Memory RAM. my other motherboard was a Gigabyte GA-MA78GM-S2H and I upgraded because of this same particular error. (note: the Gigabyte GA-MA78GM-S2H doesn't have a CPU-NB Volt on BIOS, and wasn't very good for OCing, another factor for the upgrade).
    I also posted on overclock.net but people couldn't help me very much, that's why I'm here
    I am trying to Overclock my RAM modules to 1000MHz 5-5-4-12, I've tried 960MHz 5-5-4-12/5-5-5-15, 1000MHz 5-5-4-12/5-5-5-15 and all were NO GO.
    My spec:
    AMD Phenom II X4 955 *BE* @3.85GHz atm
    Gigabyte MA790X-UD3P F5 Bios
    2x2 G Skill Black Pi 800MHz 4-4-4-12
    CoolerMaster eXtreme Power 550W PSU
    Nvidia GeForce XFX 9800GTX+
    320GB S-ATA II / 80GB IDE as storage.
    http://valid.canardpc.com/show_oc.php?id=1155978
    Did you overclock CPU-NB to x11 2200MHz? CPU-NB Voltage +0.1V
    Raising NB and HT Voltage may help as well.
    Let me know how that goes.
      Since I'm new on this motherboard, I gotta get used to it, I still don't know how good I can go with my CPU-NB Volt, as for the CPU-NB Link I set it depending of the FSB, always limiting from 2000 ~ 2400MHz...
      When I had my RAM OCed @1000MHz, that was the spec: 250 FSB, 14x Mult = 3500MHz, and tried many CPU-NB Volts. all were NO GO, from +0.1 to +0.3.5, it was unstable all the time...
      I've tried to push the vDimm to 2.1V see how that goes and yet was unstable.
      CPU-NB Link was @2250.
        NB and HT Voltage may help stabilize as well.
          Hello again,
          In the past 2 days I've been trying to OC my RAM to 1000MHz, tried all possible matches, all were a NO GO, I started at 1000 @5-5-5-15 with 2.1V, and 1.25 CPU-NB Volt, and started raising, 1.275, 1.3, until 1.5V CPU-NB Volt, all were a NO GO, then I did the same steps but with 2.2V, same thing.
          I'd like to know if Gigabyte boards are not very good on OCing RAM?
          Thanks.
            No, it mainly has to do with the AMD CPU memory controller. If you are raising CPU-NB Voltage, you might as well oc the Northbridge to see if that will help. Sometimes setting NB Frequency to x11 2200MHz can help with overclocking.
