f2-6400cl5s-2gbpq on Asus M3N78-VM - Please help
  • f2-6400cl5s-2gbpq on Asus M3N78-VM - Please help
    Memory type: G. Skill f2-6400cl5s-2gbpq ( 4 modules )'
    Motherboard: Asus M3n78-VM
    CPU: AMD Phenom II x4 940
    I can only get the system to boot with 1 memory module installed. When I try any more than that, be it 2, 3, or all 4, regardless of which slot I try, I get no display and no beeps.
    Please advise,
    Thank you!
    Try the other 3 modules in that same slot and see if they work. If so, either the motherboard or CPU may be defective.
