I haven't built a PC in years so my hardware knowledge is a bit lagging. I bought a Gigabyte GA-MA78LM-S2H board and one stick of G.Skill F2-6400CL5S-1GBNQ (1GB, DDR2 800). This is for a friend who's on a budget, so I'm leaving 1 of the 2 DIMM slots on the board open, he can add another stick of the same type later if he wants.
I'm a bit confused about dual-channel memory. This Gigabyte board has a dual-channel memory controller, the idea is to add another 1GB stick later so that both run in dual-channel mode. This G.Skill memory I bought is a retail box, on the back of the box it's written SINGLE CHANNEL in large letters. The Wikipedia article on dual channel says that memory sticks are not classified as single- or dual-channel, only motherboards (if capable), and "any matched pair of memory modules may be used in either single- or dual-channel operation".
Why is your memory labeled single-channel on the box? If he adds another stick of F2-6400CL5S-1GBNQ, will the pair run in dual-channel mode? Thanks
