Hello, my name is Iv?n Mackeprang and I'm having problems with one of my memory sticks..
My computer configuration is the following:
Model of the motherboard: Gigabyte GA-MA78GM-US2H (Rev. 1.0) with latest BIOS version.
Model of the memory: 2x1GB F2-6400PHU2-2GBHZ
Model of the CPU: AMD Phenom II 710 X3
Operative system: Windows 7 Ultimate 32 Bit
THE PROBLEM: when I turn on the computer (with both modules installed), it isn't able to boot (black screen), and then emits two "beeps" that indicate a memory fail.. I have tested each module individually, and with one of them the system boots successfully, but with the other, no.. I have tested this stick in the four memory sockets of my motherboard, and in any case the computer wasn't able to boot. I also tested this module in other motherboard (Asus M2N-MX SE Plus) and I get the same results.
I would like you to give me a response about this problem, cause I understand this product has lifetime warranty..
Greetings from Argentina, Iv?n.
