CPUZ's "memory spd" shows my memory as "PC2-6400", how can I get it at PC2-8500? I have raised the voltage from 2.0 to 2.1 with no change. Under "Chipset & Memory" it shows "Memory Frequency 533.3 MHz (5:8)." Is it running at 800 or 1066? Heres my system.
CPU-Z 1.49 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 per processor
Name Intel Core 2 Duo E8600
Code Name Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz
Package Socket 775 LGA
Family/Model/Stepping 6.7.A
Extended Family/Model 6.17
Core Stepping E0
Technology 45 nm
Core Speed 1999.8 MHz
Multiplier x Bus speed 6.0 x 333.3 MHz
Rated Bus speed 1333.2 MHz
Stock frequency 3333 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache (per processor) 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache (per processor) 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache (per processor) 6144 KBytes, 24-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel P45/P43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
CAS# Latency (tCL) 5.0 clocks
RAS# to CAS# (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Command Rate (CR) 2T
System
System Manufacturer Gigabyte Technology Co., Ltd.
System Name EP45-UD3R
System S/N
Mainboard Vendor Gigabyte Technology Co., Ltd.
Mainboard Model EP45-UD3R
BIOS Vendor Award Software International, Inc.
BIOS Version F5
BIOS Date 11/17/2008
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 2048 MBytes, G.Skill
Module 2 DDR2, PC2-6400 (400 MHz), 2048 MBytes, G.Skill
Software
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001)
DirectX Version 10.0
Processor(s)
Code Name Wolfdale
Core Stepping E0
Technology 45 nm
Chipset & Memory
Memory Type DDR2
System
System S/N
BIOS Version F5
Memory SPD
Software
