Model of the motherboard: ASUS M4A78 PLUS - Last BIOS update made
Model of the memory: F2-6400CL5D-8GBPQ
Model of the CPU: AMD Phenom II X4 965 Black Edition
Problem:
PC does not power up at all -- no POST, no beep code.
If I remove the RAM, I get a "memory error" beep code.
If I replace the RAM with a 2GB stick from another PC, everything boots fine.
Same problem as mentionned here : http://www.gskill.us/forum/showthread.php?t=3961
I've tried every slot possible, it didn't help. I've also tried to put manual frequency and voltage, it didn't help either. I didn't try any other manual setting.
Any clue ?
Problem:
Any clue ?
