F2-8500CL5-2GBpk on a GA EP43-UD3L
  • F2-8500CL5-2GBpk on a GA EP43-UD3L
    i would like to know what are the optimal bios settings for my memory.
    This are the current specs:
    Cpu: e5200 @ 3.75ghz (300 fsb x 12.5)
    Motherboard: GA ep43-ud3l (F4 bios)
    Memory: 2 x F28500CL5 2 gb (for a total of 4gb). (installed in channel 1 and 3)
    i don't know how to take a screenshot of my bios settings, but i do know the fsb:dram ratio is currently at 3:4 and i have the memory running at 4-4-4-12 with a command rate at 2t and running at 800 DDR.
    are these the optimal settings?
    everytime i try to change the memory multiplier my computer will not post, it will just keep rebooting until bios goes back to default.
    if you would like to run with FSB 300, you could set DRAM frequency to DDR2 900
    but for timing, you may need to try to find out your best timing
    thanks
    G.S
      i've tried 900 but i get random blue screens when playing games
        might try at 5-4-4-12 and possible increase NB Voltage .05 or .1
          you may try to set 5-5-5-15@DDR2 900 with default NB voltage
          thanks
          G.S
