Hello, I have been looking for the height measurements for the PC2 9600 PI and Trident
(F2-9600CL5D-4GBPI, F2-9600CL5D-4GBTD) memory sticks but can't seem to find them anywhere. I need to know the height because I have a Thermalright CPU cooler that will be in the way if the memory is to tall with the heat sinks. I can turn it but then I will have to find a way to rig the side mount fan.
Also, what are the differences between the PI and Trident? I know the Trident is low voltage, but is that it? What qualifies it for the award on G Skill's website?
System Specs:
Windows XP 32bit
Asus P5Q Pro motherboard
E8400 OC to 4.2 GHz
OCZ Fatality 1066 RAM
I know all 4Gbs won't show up on XP. I am planning on upgrading to Windows 7 64bit sooner or later so it won't really matter.
Thanks a lot for your help.
Chasse
System Specs:
Windows XP 32bit
E8400 OC to 4.2 GHz
Chasse
