I have this configuration for 6 year now and I'm experiencing more and more freezing of my PC most of the time within the 2 to 5 first minutes when I start it.
I did look on windows 7 for a while, but stop looking there when I experience the same freezes when I was on BIOS or running on prompt a MEMETEST86.
Now I have some doubt on the parameters used on the BIOS.
Timmings are set up manually as : 4-4-4-12, but voltage is set at 2.100V... which is not matching G.Skill recommendations. I'm surprised for this, but as this configuration has been done by the shop where I purchase the computer (Materiel.net in france), I nerver look to the parameters...
I also read on the web that G.Skill RAM can be set above the redommended ones at 2.1V...
This is whuy I prefer to ask directly to the manufacturer and based on the mother board, what would be your recommendations?
May I also asked you as well what other parameter should be set for this mother board?
In the same time I had since yesterday decrease the voltage to 1.800V, but I need to test the PC for few days, becasue the problem only occurs when power on and also randomly...
Thanks a lot in davnce for your advices.
Alch
Alch
