F2-6400CL4D-4GBPI-B Compatible mobo Question.
  • F2-6400CL4D-4GBPI-B Compatible mobo Question.
    Hello gskill people , i am about to purchase two set of this ddr2 F2-6400CL4D-4GBPI-B.
    total: 8 gb . this will work fine whit this config ?
    Gigabyte Ga-ma78gm-us2h rev 1.0
    Phenom 2 940
    thank you .
    That memory package is compatible with your Gigabyte GA-MA78GM-US2H motherboard, but you may need to make BIOS adjustments such as increasing Northbridge Voltage and setting Advanced Timings to allow for the extra 4GB. Depending on the motherboard, it can cause a memory controller overload.
    We do not guarantee 4 sticks to work since it depends on the motherboard, but previous customers have been successful.
      hello thanks for the answer, i think i gonna purchase 1 set by the moment.
