hello,
i am having some trouble with my ep45-ud3p and f2-8500cl5d-4gbpk. i have followed the guide for this setup, and it still does not seem to work. it constantly reboots if i set the speed anywhere higher than ~925. if i use one of the dividers and bring it down below 925, then the system will boot fine until its restarted. if i restart the computer, with will get stuck in a reboot loop for 3 cycles or so an then will boot into bios. when i enter the bios i get the red screen telling me that the settings failed.
when i get into windows, everything works fine. i have prime95 inplace large fft run 58 hours with no errors and small fft run for 13 hours and no errors.
i would really just like to get it to be able to keep the settings it has programmed and not constantly reboot if the computer is restarted. i am not looking for a huge overclock on this just to get the ram to run at rated speeds. i have overclocked the system with other ram and found it to be stable up to 4+ghz, so i know its not a cpu instability problem. with the other ram i do not get the constant reboot problem, but i am only using 2 x 1gb 533 sticks.
i have tried countless combinations of voltage settings, but can not seem to get rid of the problem. so i am hoping someone can provide me with a little guidance.
any help is greatly appreciated. sorry for such a long post. thanks!!
ep45-ud3p is a rev 1.6 board with FB bios
cpu is pentium 4 630 prescott
memory is 2 x f2-8500cl5d-4gbpk
os is windows server 2008
here are my bios settings.
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...[AUTO]
CPU Clock Ratio ...........14X
Fine CPU Clock Ratio.......0.0
CPU Frequency .............3.724 GHz (266*14)
Clock Chip Control
>>>Standard Clock Control
CPU Host Clock Control.......[Enabled]
CPU Host Frequency (Mhz) ....266
PCI Express Frequency (Mhz)..100>>AUTO
C.I.A.2 .....................[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive..................[700mV]
PCI Express Clock Drive..........[700 mV]
CPU Clock Skew (ps)..............0ps
MCH Clock Skew (ps)..............0ps
DRAM Performance Control
Performance Enhance..............[STANDARD]
Extreme Memory Profile (X.M.P.)..[Disabled]
(G)MCH Frequency Latch...........[Auto]
System Memory Multiplier ........[3.33C]
Memory Frequency (Mhz) ..........1066....889
DRAM Timing Selectable ..........[Manual]
Standard Timing Control..trial1
CAS Latency Time...5 [5]
tRCD ..............7 [5]
tRP'...............7 [5]
tRAS...............20 [15]
Advanced Timing Control
tRRD...............4 [AUTO]
tWTR...............4 [AUTO]
tWR................8 [AUTO]
tRFC...............68 [80]
tRTP...............4 [AUTO]
Command Rate (CMD).0 [2]
Driving Strength Profiles
Driving Strength ......
>>Channel A
Static tRead Value........3
tRD Phase0 Adjustment.....0 [AUTO]
tRD Phase1 Adjustment.....0 [AUTO]
tRD Phase2 Adjustment ....0 [AUTO]
tRD Phase3 Adjustment.....0 [AUTO]
Trd2rd(Different Rank)....6 [AUTO]
Twr2wr(Different Rank)....6 [AUTO]
Twr2rd(Different Rank)....5 [AUTO]
Trd2wr(Same/Diff Rank)....8 [AUTO]
Dimm1 Clock Skew Control....[AUTO]
Dimm2 Clock Skew Control....[AUTO]
DDR Write Training..........[AUTO]
Driving Strength Profile......[AUTO]
Data Driving Pull-up Level....[AUTO]
Cmd Driving Pull-up Level.....[AUTO]
Ctrl Driving Pull-up Level....[AUTO]
Clk Driving Pull-up Level.....[AUTO]
Data Driving Pull-Down Level..[AUTO]
Cmd Driving Pull-Down Level...[AUTO]
Ctrl Driving Pull-Down Level..[AUTO]
Clk Driving Pull-Down Level...[AUTO]
>>Channel B
Static tRead Value..........3
tRD Phase0 Adjustment.......0 [AUTO]
tRD Phase1 Adjustment.......0 [AUTO]
tRD Phase2 Adjustment ......0 [AUTO]
tRD Phase3 Adjustment.......0 [AUTO]
Trd2rd(Different Rank)......6 [AUTO]
Twr2wr(Different Rank)......6 [AUTO]
Twr2rd(Different Rank)......5 [AUTO]
Trd2wr(Same/Diff Rank)......8 [AUTO]
Dimm1 Clock Skew Control......[AUTO]
Dimm2 Clock Skew Control......[AUTO]
DDR Write Training............[AUTO]
Motherboard Voltage Control
Voltage Type
>>> CPU
Load-Line Calibration [ENABLED]
CPU Vcore...............1.3000v....[1.400] <--max i can set
CPU Termination…........1.200v....[1.260]
CPU PLL………….............1.500v....[1.500]
CPU Reference.............0.760v....[0.768]
>>>MCH/ICH
MCH Core.........1.100v...[1.500]
MCH Reference....0.760v...[0.758]
MCH/DRAM Ref.....0.900v...[1.000]
ICH I/O..........1.500v...[1.500]
ICH Core.........1.100v...[1.100]
>>> DRAM
DRAM Voltage ........1.800v...[2.100v]
DRAM Termination.....0.900v...[1.000]
Channel A Reference..0.900v...[0.900]
Channel B Reference..0.900v...[0.900]
also if someone could please explain the different memory dividers this board has, as i am not very familiar with what these mean as all my other systems have been amds.
also which of these would be best to use to bring it down to 800?? right now i am currently using 3.33C
x.xxa -> fsb 266mhz
2.50a
3.00a
4.00a
x.xxb -> fsb 333mhz
2.00b
3.20b
4.00b
x.xxc -> fsb 200mhz
2.66a
3.33a
4.00a
x.xxd -> fsb 400mhz
2.00d
2.66d
3.33d
thanks again
Clock Chip Control
>>Channel A
>>Channel B
Voltage Type
>>> CPU
>>>MCH/ICH
>>> DRAM
x.xxa -> fsb 266mhz
2.50a
3.00a
4.00a
x.xxb -> fsb 333mhz
2.00b
3.20b
4.00b
x.xxc -> fsb 200mhz
2.66a
3.33a
4.00a
x.xxd -> fsb 400mhz
2.00d
2.66d
3.33d
thanks again
