Motherboard: XFX MB750I72P9
Memory: F2-8500CL5D-4GBPK
CPU: E6600
While the system boots fine at 2.1V for the RAM and 800 for the memory, as soon as I start pushing the memory to 1066 and give it 5-5-5-15, it starts giving me boot issues. From reading the other threads I've tested varies timings and voltages for the memory, northbridge and southbridge with no luck. While it's booted occasionally, a quick MemTest+ results in errors from the get go.
Personally I think the bios is a piece of crap because it does not give you the control that previous bioses(?) that I've used have. That being said, all the settings I do have to set to get this to work are available. Could someone help me figure out the right timings and voltages. I'm fine increasing the voltages as long as I don't blow anything.
Thanks!
CPU: E6600
Thanks!
