Hi peeps,
I built this PC around 8 months ago and was immediately able to attain an FSB of 1600, link/sync the RAM (Mushkin at the time) to run at 800mhz with 4.5.4.11 timings. All I play is WoW, so with it being such an incredibly CPU intensive game, the CPU frequency is critical. With the 1600FSB and CPU/RAM linked/synced it was humming along and was even able to maintain 40fps in Dalaran (most populated city in the game ? can crunch an i7 without blinking) with 60-80 addons running.
But one of the sticks went bad and so I went on Newegg and saw this set and how it runs at such appealing voltages and ordered the set. I initially linked/sync?ed it at 1600FSB but left the timings at 5.5.5.15 for the first few days to make sure I was stable. I then bumped the voltage to 1.9v and set them at 4.4.4.12 and was rockin for about a week before I started to have problems.
WoW began to app crash citing error #132 (RAM error) quite frequently. I loosened up the timings and became much more stable, but still crashed from time to time. Finally, I backed the FSB down to 1580, so the RAM is now running at 790mhz. At this FSB, I am now using 4.4.4.10 timings and have been stable for a month with this setting.
But getting back to wow being so CPU hungry, I am responsible for Frapsing my guild?s raids and raiding wow with all these addons and Fraps recording is extremely demanding on any PC and mine is struggling to maintain 30fps (I record Fraps Full Size @ 30fps) in the middle of the encounters. In these situations, every single FPS is critical (and not to mention, the movies look better too if they record at a steady 30fps).
So, my question to you guys is, if you were me what would you try to do? Do you believe the RAM is what?s struggling to run at its rated speed or is it the mobo? I?ve never tried giving the RAM more than 1.9v, but I have tremendous cooling in this case, so heat should not be an issue. Also, for a game like wow, will having a higher RAM frequency make for higher fps or having the timings tighter be more beneficial?
I would like to just run everything nice and neat at 1600FSB (L/S) with timings at the stated 4.4.4.10 ideally, but I?m up for suggestions. Thanks for your help!
