7980XE & F4-3600C17Q2-128GTZR
  • 7980XE & F4-3600C17Q2-128GTZR
    Will this Kit work "easy" with the 7980XE? Whats the normal speed which a 7980xe can reach without problems?
    Does the Kit have a temp sensor?
    Is there any between the black/white/ and rgb kit (rgb of course)?
    Easy? Not exactly, 128GB of DDR4-3600 is stressful for any CPU.
    Maximum DRAM Frequency also depends on motherboard.
    If specifications are identical the RAM itself should be same/similar.
      Thanks for helping!
