Hi
my Setup:
Gigabyte Z390 Designare (laetst Bios update F9b)
i9-9900k @stock
bought 2 Different Trident Z with Samsung B-die
which showed up at the G.Skill RAM Calculator
for my Mobo.
(testet separately)
- F4-4000C17D-16GTZR
- F4-3600C16D-16GTZR
Please have a look at my provided screenshots from cpu-z
and the bios ( here i marked where i changed things)
a) 3600mhz rated pair runs stable on XMP profile
b) 3600mhz rated pair
Overclocking:
am i doing this right? Am i missing sth?
1. disable xmp
2. set manually to mhz 3600-4000.
3. play around with DRAM Voltage 1,35-1,45v
4.set Memory Channels Timing manually (CAS; tRCD; tRP; tRAS)
either the PC won´t boot or will crash when starting Battlefield V
so i ordered 4000mhz Rated pair suitable for my Mobo (according
to G.Skill calculator
4000mhz Pair won´t run stable even on XMP Profile.
What can i do?
i heard you need a good Mobo and CPU to get the RAM
stable at 4000mhz, and i thought i´d have that kind of hardware
am i just unlucky with my CPU or can i do sth to stabilize
4000mhz rated pair on xmp ?
On the BIOS screenshots you can see the Voltages of the CPU aswell
thanks guys
my Setup:
i9-9900k @stock
for my Mobo.
(testet separately)
Overclocking:
1. disable xmp
What can i do?
thanks guys
