Memory: G Skill Ripjaws V series 2x16GB 3600 CL 19 DDR4 (F4-3600C19-16GVRB)
Mobo: X570 Aorus pro wifi
CPU: 5800x
Bios: F35d
This 3-year-old set no longer posts above 2133MHz. (System seems stable at that speed, though). I Can’t get it to post at 3200, using ryzen dram calculator’s suggested safe settings (which I entered to the best of my abilities, some timing names aren’t identical on my motherboard). I then tried the xmp profile (3600 MHz, won’t post) and that same profile changing only 3600 down to 3200, staying at 1.35V. Upon reset, computer stayed idle, all fans on, for about an hour without reaching the mobo splash screen. I had to turn it off and on. When it finally reached Windows, it was back at 2400 MHz.
I should also say, as it might be related, that I’ve been having an issue with turning my computer on, where the mobo fan spins and the system seems to work for 30-90 seconds before slowing down and actually doing what used to be happening right from the start: 5 seconds of silence, showing me the splash screen and then loading windows 10.
Could anyone help?
Could the memory have gone bad? Or the motherboard? How to tell?
Here are the latest settings that I tried. Though I suspect that my problem isn't a timings problem.
CPU: 5800x
Bios: F35d
Could anyone help?
