Hi tweakers
I recently bought a new PC, AMD 5950X, with ASUS ROG STRIX X570-E mainboard.
Ive checked the calculator for the best Ram to buy for this setup and went with the F4-3800C14Q-32GTZN.
There is only currently a Issue. I can't set it up @ 3800 MHZ in the bios.
I am currently using their latest Bios version. And switched on DOCP. and manually selected DDR4-3800MHZ and FLCK 1900 MHZ.
After saving the setting my pc won't boot and I get prompted to enter my bios again.
I can get it to work when I switch to DDR4-3600 / FLCK 1800.
Does anyone have tips. which setting I can play with to get this ram sticks working on 3800 CL14
Kind Regards,
Kevin
Kind Regards,
Kevin
