G.Skill F4-3200C16-16GTZR
  • G.Skill F4-3200C16-16GTZR
    Hello, I can't get 3200 to work on asus tuf x570 by activating DOCP memory kit G.Skill F4-3200C16-16GTZR. The bios is 1405. Anyone have suggestions or solutions? thanks
    Are modules installed in slots A2 B2?
    Try one at a time in A2 to see if they can work with DOCP alone. Another test is with DOCP Profile enabled and lower DRAM Frequency until the system can work properly. The results should provide more insight to what may be going on.
      The modules are correctly in a2 b2. I managed to get it working by manually setting FCLK to 1600 but I have a hardware error when doing memory diagnostics in windows.
      thanks for the quick answer
