Here is my setup :
F4-3200C14D-16GFX 3200Mhz 2x8Gb
MSi X370 Gaming pro carbon
Ryzen 7 1700X
I use the v1.80 of the bios.
I can get the ram to work to 3200Mhz with a stable OS, but the computer always reboot multiples times before i have the the mobo POST message. I've tried both Xmp1 and 2 settings, and alos tried to manually set 14-14-14-34 and 1.35V in settings, but it's always the same : reboot reboot reboot, and then it boot. Sometimes more than 5 times so the settings are resettings...
i'm a bit confused. so i have two question :
1) Wich setting should i use to run ram at 3200Mhz withut this boot issues. i'm a noob on overcloaking, so explaination are welcome.
2) what are the risk ? i guess if the setup is rebooting it means what there is a damage protection or something else ?
thank in advance
Here is my setup :
Ryzen 7 1700X
thank in advance
