Well, I'm making a new computer, and I keep noticing that the RAM sticks are optimized or built for either intel or AMD, the computer that I want to build will be an AMD Phenom II x6 processor with an ASUS M489GTD PRO/usb3 and I really want to buy some form of RAM that can fully utilize it's DDR3 2000 capabilities, now the obvious choice is the flare: F3-16000CL7D-4GBFLS, but i was wondering if I could run ram, such as the PIS F3-16000CL9D-4GBPIS which says that it is for intel on my AMD board.
ram compatibility
Yes, you just want to make sure your system is capable of the specs.
Some people purchase DDR3-2400 for their AMD 720 with 785 chipset... then ask me why the heck it only works at DDR3-1333... that's the reason why we state "Intel only" "AMD 6 core only" and such limitations. They aren't necessarily ONLY, but only certain hardware can support the specification.
GSKILL TECHLast edited by GSKILL TECH; 08-03-2010, 10:32 AM.
