Gskill 4GB DDR3 2000mhz F3-16000CL6D-4GBPIS
I recently pick up 2x2 gigs of Gskill 4gb DDR3 2000mhz F3-16000 CL6D-4GBPIS I have them currently running at there rated 2000mhz speed. the timings are 7-9-7-24-40 1T 1.70v crosshair iv formula motherboard and amd phenom II 1090t at 4000mhz 1.45v. this memory can be very finicky and took a while to get it stable at this speed it will run with no problems all the way up to 1800mhz 1.65v timings 6-9-6-24-40 2T. to get the memory up to 2000mhz rated speed I had to do some tweaking in the bios to get memory up to 2000mhz I had to raise the voltage to 1.70v. NB to 1.45 NB frequency 2759mhz. I thought I could post some pics of my results but I do not know how this is my first post. and looking around at some of the post different members seems to be having the same problems. Thanks g.skill for the quick reply all my setting are rock solid I have used prime95, memtest both with out erors.
- 1 like
