Trident Z5 RGB Light Guides/Diffusers
  • Trident Z5 RGB Light Guides/Diffusers
    I broke the light guides that diffuse the RGB light on my DDR5 Trident Z5 RGB modules while removing them for modding purposes. Is there any way I can purchase them from G.SKILL? I mean I can live without them but I want them back on. Who would I need to contact to see if it's possible to even get these? I see no parts page, only warranty and tech questions. Thanks for the help!
    Unfortunately I don't think you can buy these as a spare part. You can always contact tech support directly, if you want to make sure.
    Is it not possible to fix them back up with some glue?
    Worst case that might become an issue later, since the warranty requires the modules to be in their original state.
      G.Skill does not offer replacements, however I have seen some third party copies online but they were crystal Royal style
