4000 CL15 feedback
  • 4000 CL15 feedback
    Hello everyone!
    First, I really appreciate G.Skill brand because they provide the most extreme performance memories!
    But, summer is coming in my country, and temperatures are rising (30°c).
    And I am facing memory errors on XMP setting with my new DDR4 kit: 4000MHz CL15-16-16-36 1.50V 2x8GB (Ripjaws V).
    These errors always appear when modules reach 58°c.
    I tested at CL16 (16-16-16-36) and no more errors, even as high as 63°c (can't go higher).
    So my question is simple: what is the max safe temperature to run XMP without any errors?
    Asking it another way: what maximum temperature G.Skill use during stress tests to guarantee stability on their rated XMP settings?
    From my experience as an overclocker: The higher the frequency/voltage and the tighter the timings, the lower you may have to keep the temperature. The specific temperature threshold for certain settings can vary from one kit to another. In general you want to keep B-Die based kits below 50°C for very tight overclocks and the XMP of your kit is already pretty extreme
    Temperature based instabilities are easy to confirm though, just give the modules some additional airflow and the stability should return with the temperature reduction.
      Thank you both for your answers.
      My point was: temperature is a key point for RAM stability, but it's not mention anywhere on the spec.
      Something like this for instance XMP: 4000Mhz at 15-16-16-36 tested max 60°c.
      I mean you can kill your OS and risk to loose all your data if you reach the temperature limit of your memory, and it depends from one kit to another, and the buyer must know it.
      I have tested mine to be stable until 58° at stock XMP settings before risking to loose my system.
      Am I the only one to be concerned we are so far from JEDEC standard 85°c?
      I am not saying I will not buy a fast memory kit even not stable below 85°, I am just saying we need to know max safe temperature for each memory kit when buying, to adapt sufficient cooling and avoid loosing our data...
        1. G.SKILL DDR4 memory modules are not designed with temperature sensors. This applies to all G.SKILL DDR4 memory modules.
        Therefore, the temperature data shown through the software may not accurately reflect actual IC temperature.
        2. The memory IC chips are rated for operation up to 85°C, when measured directly at the IC.
        What this means is, even if there is a temperature sensor on the module, it's not measuring the IC chip temperature. It would be measuring temperature from a different location. So the DRAM temperature reported in the software is not reliable enough to conclude that the memory temperature is the source of error.
        3. With any PC hardware, cooler temperatures mean better stability. We understand this, which is why each memory kit is hand tested under XMP specifications on actual systems to reflect real world usage. No additional memory cooling is used during validation.
        During these validation tests, memory IC chips need to maintain stability at the rated settings regardless of the temperature. So even if it fails at a temperature lower than 85C, then it fails and won't be made into a retail kit at that specification. Only the memory kits that pass will become retail memory kits.
        This also means that it is also important to keep other components cool as well, such as the CPU temperature, which may also be a point of failure. Based on our experience, we would be more concerned about maintaining CPU temperature in order to stabilize the memory kit operation.
        Based on the system information we received from you through eurotech@gskill.com, the i9-9900KS is a processor that may also run very hot. In the screenshot you have provided, it seems to indicate that the CPU temperature is running at about 75C, with a maximum peak of 85-87C, which is pushing toward the high end. Such high CPU temperatures would likely lead to issues with memory stability, more so than memory temperature. We have noticed that the fans seem to be operating only at 800rpm to a max peak of 1400rpm, which is on the low end in terms of fan speed, especially when CPU is on load.
        So there are a few things we'd like for you to try.
        1. Increase fan speed for your CPU cooler to lower the CPU temperature. Based on the screenshot, you might be using a NZXT cooler, and on some NZXT coolers, their CAM software is required to set the fan speed and pump speed to higher speeds, otherwise it will default at a low base speed. If the fans are connected to the motherboard fan headers, then you may need to change the fan speed through the BIOS. If the fans are on a 3-to-1 or 2-to-1 cable splitter, then the fans may also be sharing power, which is not optimal. It's recommended to connect fans to its own power connector.
        2. We do not know if you're overclocking the CPU or if the CPU settings are at default settings. Default CPU settings are highly recommended. Overclocked CPU would increase CPU temperature, and high CPU temperature would affect memory stability.
        3. Ensure you have proper case air flow. Please make sure to have at least 1-2 fans for pushing air outwards. If you are using a liquid AIO cooler, please also make sure that the radiator is set up so that the fans are blowing outwards. If you have additional case fans at the front or on the side panel, those can be set up to blow air into the case. This is to prevent warm air being trapped inside the case, and to make sure that air is properly cycled throughout the system.
        Please check and do the above steps and let us know the results.
        Thank you.
          Thank you.
          Hi sir,
          thank you very much for your time to write a proper reply, very appreciate!
          Indeed, very fast memory can be tricky, especially depending on the trio: [RAM quality]+[CPU IMC]+[Motherboard capacity]
          And I like to test the limits of my new hardware.
          So I slow down my fans on purpose, to let memory temperature increase and find its stability limit.
          And I noticed it was always around 58°c, based on this sensors called "DIMM[]" and regardless of my CPU temp.
          You said G.Skill modules have no temp sensors inside, then I assume they are provided by my Asus motherboard (Nuvoton NCT6798D ISA Sensor Device), but that doesn't make sens because all monitoring softwares call them DIMM temperature, and not "DIMM slot" temp.
          In this case, if I have no possibility to monitor the real temperatures inside the RAM modules, only I can guess they must be higher.
          What concerns me, is that when I play games, this DIMM[] temperatures increase to around 55°c because of the GPU hot air inside the case and hot weather.
          It means I am getting too close to the limit I found (58°) where I can encounter some memory corruption on my system and risk to loose data.
          It's why I tried to relax CL just by one unit from 15 to 16, in order to have more 'appropriate' 16-16-16-36 at 4000Mhz, and thanks to this timings it become stable, even as high as 64° (max tested, can't go higher), no matter CPU temperature.
            Add the screenshot about my errors starting from 58°c at default XMP:
Name:	Stabilite defaut error 3.png
              I did some testing again, and I get rid of the errors just by increasing RAM voltage from 1.50 to 1.52v.
              No more errors, even as high as 64°c, and even with tighter secondary timings!
              It means that either voltage was not enough, either such high speed and low latency was too optimistic (4000Mhz CL15)
              My point is not to blame G.Skill, but RAM stability is critical, in order to avoid silent corruption and data loss.
              It should remain stable at least until 60°c (not mentioning Jedec 85°c)
              It's why it's very important to add the key information of max safe temperature for running XMP in the spec, such as:
              XMP1: 4000Mhz 15-16-16-36 max 55°c
              XMP2: 4000Mhz 16-16-16-36 max 60°c
              XMP3: 3800Mhz 16-16-16-36 max 65°c
              Thank you to consider my recommendation to improve your nice products even more compare to other brands...
Name:	stress 4000 15-16-36 tuned 1.52v IO1.15 SA1.20 - 6XX.png
                Just to say this modules are beasts!
                So fast, even at default primary timings, and with my personal touch for secondary timings!
                Moreover, it is safe until 64°c at 1.52v!
                Good job G.Skill, I've ordered a second set of this very same modules, to have 32GB of crazy fast memory
                Click image for larger version  Name:	RAM 4000 CL15 - default primary - optimized secondary.png Views:	0 Size:	1.65 MB ID:	164641
                  I received my new set of the exact same kit for a total of 32GB (4x8GB)
                  They work perfectly fine all 4 together
                  Except for the same problem of too low temperature to run default XMP which starts to throw errors above 50°c.
                  In my case, my dimms can reach 55°c during heavy gaming (big air GPU)
                  I solved this problem just by increasing a little bit the RAM voltage from 1.50 to 1.52v, which gives about 10°c more safety room until 61°c
                  Click image for larger version  Name:	stress 15-16-36 opti 1.52v 1.20-1.25 61-err mem.png Views:	0 Size:	723.9 KB ID:	164674
                  About bench, in addition to the bigger RAM size, I can see some improvements for copy bench (54->57GB/s) but a slight worse latency (37.5->38.5ns)
                  Click image for larger version  Name:	bench.png Views:	0 Size:	213.8 KB ID:	164673
                  Nonetheless, I beat my record at Time Spy CPU bench with a score of 13 455 !
                  https://www.3dmark.com/spy/12542919
                  (with my daily usage high stability setting)
                  This benchmark scales very well with faster RAM.
                  Just check the ranking: https://www.guru3d.com/articles-page...review,18.html
                  Overall, I am very happy with my purchase, especially for Ripjaws with 2 things I like more vs Trident:
                  - no need of background process just to turn off RGB
                  - low profil size in the middle (made on purpose?) providing better clearance to the first dimm slot which is just next to the CPU AIO cooler (like my NZXT X62)
                    Just to add last information about my topic subject of RAM temperature, and as said previously by G.SKILL Administrator, the thermal sensor (which is located somewhere on the PCB), is not giving the exact temperature inside the memory chip, which should be higher. But how much higher? Only the maker know, because it depends on its exact location.
                    I found some technical information below in case some people are interested in this subject.
                    Again, RAM temperature is a critical point to monitor, in order to avoid system corruption and data loss.
                    And the only tool we have at our disposal, is the report DIMM thermal sensor.
                    In my case, default XMP with 1.50v can rises rapidly above 50°c during heavy gaming, because of big air GPU and high ambiant temperature.
                    And the difference/delta is too close to the limit where my memory IC chips start throwing errors because of the degraded signal caused by higher temperature.
                    For peace of mind, I recommend people to check their own safety temperature limit, especially with 1.50v modules that can increase faster.
                    And if too close to the limit, just rise the voltage a little to have more safety room (in my case +10°c limit with 1.52v)
                    Memory binning is very interesting process, and I wonder if someone at G.Skill can provide more general information (not confidential) like a ranking of their binning chips to know for instance if my new 4000 CL15 at 1.50v is better than the old 4000 CL17 but running lower voltage 1.35v (can it get to the same CL15 just by increasing voltage to 1.50v?)
                    Because sometime, prices don't always reflect the real performance ranking...
                    Thank you G.Skill!
                    http://ww1.microchip.com/downloads/e...Doc/22327C.pdf
                    Click image for larger version  Name:	ddr4_temp_sensor.png Views:	0 Size:	610.0 KB ID:	164701
                      Some news after one month playing with these nice puppies
                      As a reminder, I've bought 2 different sets of 2x8GB 4000 CL15, and they work perfectly fine all 4 together.
                      I've fixed a little fan over them to decrease temperature about 10°c while gaming:
Name:	photo fan ram.jpg
                      Now that they are cool, it's rock stable for my daily usage at 1.50v with default primary timings and tight secondary (instead of 1.52v without fan).
                      Just for fun, I have also played with fequency/timmings, and they scale nicely with voltage when kept cool!
                      For benching purpose, I've pushed voltage to a max of 1.59v (just once because I'm not confortable with high voltage)
                      And they can reach a very fast latency of only 34.5ns at 3700 13-13-28!
Name:	3700 cl13 34.5ns.png
                      Definitely happy with these modules, especially Ripjaws version, because they are low profile for better compatibility with CPU AIO cooler, and with no childish RGB you can't disable without background process (and can add heat a little).
                      Really good idea to offer Ripjaws for these crazy fast memories
                        Hello, thanks for your feedback!
                        I own this Kit too (32GB Kit) - with a 9900KS & Asus Maximus XI Extreme.
                        Could you boot out of the box at 4000 CL15 ?
                        What was the trick?
                        I already own some G.Skill kits which runs perfect stable at 4.100 16-16-36,
                        but with this Kit i can only run 3.600 cl15
                        All above 3.700 end in a black screen...
                        Did you run Mode 1 or Mode 2 ?
                        It does not matte how high i set the vccio & vcssa voltage (xmp gives to much up to 1,40v !!)
                        Thanks for helping!
                        BTW: the strange - i cant run this Kit stable via 4.100 CL16 too - and i thing this MUST work for this special selected kit !
                        Temps is not a problem of this kit - even with 1,52v - below 50 degrees.
                          What was the trick?
                          Thanks for helping!
                          Hi, sorry for my late answer.
                          We have almost the same system.
                          With this kit, you must use Asus Mode 1 only, because Mode 2 sets tighter secondary and tertiary timings which don't work for higher frequencies (above 3800Mhz).
                          After playing a lot with this memory modules, I have finally found the best settings to have both performance (better than stock) and maximum stability.
                          Feel free to try it, but remember it depends on your hardware quality, especially on your CPU IMC.
                          Knowing G.Skill provide modules after testing them to be stable at some primary timings, but all other timings are choices/guesses made by the motherboard manufacturer and can be far from optimal for some memory kits (update your MB bios).
                          In case it fails to boot with below settings, try tertiary timings on auto.
                          4000 16-16-36-2 Mode 1
                          VCCIO: 1.20v
                          SA: 1.24v
                          tRRDL 6, tRRDS 4
                          tRFC 416, tRFC2 312, tRFC4 192
                          tREFI 16640, tWR 12, tRTP 8, tFAW 24
                          tWTR 8, tWTRL 8, tWTRS 4, tCKE 8, tWCL 14
                          tRDRD_sg_dg_dr_dd 6 4 6 6
                          tRDWR_sg_dg_dr_dd 16 16 16 16
                          tWRWR_sg_dg_dr_dd 7 4 7 7
                          tWRRD_sg_dg_dr_dd 28 24 7 7
                          tWRPRE 30, tRDPRE 8
                          tREFIX9 127, OREF_RI 64
                          RTL/IOL
                          73 66 66 68 68
                          4 13 13 14 13
                          21 21 14 14
                          Results in bench Aida:
                          Read: 60 252 MB/s
                          Write: 61 982 MB/s
                          Copy: 58 282 MB/s
                          Latency: 39.1 ns
                          Ram voltage stability check
                          Stressapptest (boot to Linux USB, to avoid Windows corruption)
                          1.40v first error at 450s
                          1.41v no error after one hour (RAM reached 51°c)
                          1.42v Safe
