Can you change top plastic piece on TridentZ ram?
  • Can you change top plastic piece on TridentZ ram?
    Was about to buy this in Black and Silver: Model F4-3200C14D-32GTZSK
    But it sold out right before I could buy so went with White and Silver instead.
    Really wanted black n Silver. Any way to change the top plastic piece?
    No, unfortunately not.
      Well a review I read stated that you can remove the pastic piece if you want. So your dimms will look all silver as opposed to Silver and White.
        The piece is clipped in on both sides, so you can remove it . However keep in mind that if you damage something while doing so it might void your warranty, so be very careful.
          That’s good advice. Thanks,
