Advice for Bios settings for my DDR2-800 set and other questions
  • Advice for Bios settings for my DDR2-800 set and other questions
    Hi there. So I just did a fresh Win 7 32bit Prof install, and only now realized I can't install more than 4 gig, MS are truly morons.... Still debating whether to go 64bit, I guess I need a new printer anyway, not sure what other things might screw me with 64, I do only have 4 slots for Ram Dimms, currently I have 2 x 1gig Kingston ram and 3 x 2gig GSkill ram Dimms, and with my MB it says I can only get dual channel 2 ways, ONE matched pair OR one matched pair with and a DIMM on the other channel that is equal in size to the other 2. Find this very strange I can't install 2 matched pairs, which in my current case would be 6 gig at least, but then the Kingston ram wants 1.8V where GSkill wants 2V so not sure mixing them would work anyway (seems like it wouldn't and I would want to buy one more GSkill to get 8 ram total).
    Given all these limitations, I think for now anyway I am just going to run 2 of the 2 gig GSkill Dimms with Win 7 32 bit Prof
    My Specs:
    MOBO - Intel DQ45CB
    Chip - Intel Core 2 Quad Q9400 2.66Ghz
    OS - Win 7 Prof 32 bit
    RAM - GSkill F2-6400CL4D-4GBPK DDR2 - 800 (want to use this, just bought it)
    Current ram - Kingston KVR800D2N5K2/2G 1.8V 2 x 1gig each
    Questions:
    1. How much more efficient/faster is Dual Channel vs Single anyway? Even if I go 64bit, if I install 8 Gig of Ram it will be Single Channel mode with my Mobo, seems crappy.
    2. My Mobo apparently wants SPD, and maybe even 1.8V memory, maybe the Gskill is NOT even compatible?? I wonder how strict that 1.8V parameter is here?
    https://downloadmirror.intel.com/169...01_English.pdf
    To be fully compliant with all applicable Intel SDRAM memory specifications, the
    board should be populated with DIMMs that support the Serial Presence Detect (SPD)
    data structure. If your memory modules do not support SPD, you will see a
    notification to this effect on the screen at power up. The BIOS will attempt to
    configure the memory controller for normal operation.
    The Desktop Board supports the dual or single channel memory configurations defined
    below.
    • Four 240-pin Double Data Rate 2 (DDR2) SDRAM Dual Inline Memory Module
    (DIMM) connectors with gold-plated contacts
    • Support for:
    ⎯ Non-ECC, 1.8 V, DDR2 800/667 MHz memory
    ⎯ Serial Presence Detect (SPD) memory only
    ⎯ Unbuffered, non-registered single- or double-sided DIMMs (except double-sided
    DIMMs with x16 organization)
    ⎯ Memory configurations listed below:
    • Up to 2.0 GB utilizing 256 Mb technology
    • Up to 4.0 GB utilizing 512 Mb or 1 Gb technology
    • Up to 8.0 GB utilizing 1 Gb technology
    3. IF I should even use the Gskill, the main thing I want to know is what to change in BIOS after I install 2 of the Gskill dimms. Keep in mind I am a NOOB here, so very specific directions would be best
    Here is what is in my BIOS settings:
    SDRAM Control - Auto
    Current Mem Speed - 800
    Current Mem Setting - 5-5-5-18
    Reference Freq - Default
    Memory Freq - 800
    TCL - 5
    TRCD - 5
    TRP - 5
    TRASmin - 18
    Mem Voltage - 1.8
    Total Memory - 2048 MB
    Mem Mode - Dual
    Note SPD defined as Nominal [TCL] - TRCD - TRP - [TRASmin]
    THANKS A LOT!!!
    1. Why would it be single? Dual channel is theoretically twice as fast.
    2. It should be adjustable in BIOS.
    All G.Skill modules are SPD supported so no worries.
    3.
    Memory Freq - 800
    TCL - 4
    TRCD - 4
    TRP - 4
    TRASmin - 12
    Mem Voltage - 2.0
    Total Memory - 4096 MB
    Mem Mode - Dual
    Just need to input basic values like so. Let us know how it goes.
      Hi thanks a lot for the reply
      1. Well I noted the restrictions in configurations in the first part of my post above
      2. The settings I posted are all I have in Bios
      My biggest worry here right now is the manual for the Mobo saying it supports:
      Page 13 here:
      Have people used 2.0 volt memory in instances like this where it supports 1.8V successfully, or should I not do it?
      Thanks again
        2.0V is no problem at all
          Hi there again. So I installed the Ram, and went into Bios and what I found is I could NOT change the following parameters to what we wanted (I could not change anything, until I changed SDRAM Control - Auto, to SDRAM Control - Manual):
          TCL - 5 - It does not go below 5, choices are 5,6,7,8,9,10
          TRCD - 5 - It does not go below 5, choices are 5,6,7,8,9,10
          TRP - 5 - It does not go below 5, choices are 5,6,7,8,9,10
          TRASmin - 15 - This one I can put at 12, but really don't know if I should, given the above
          I was able to change the voltage to 2.0
          Don't know if I should use this memory now, and if you think it is okay, what settings should I use given what I have put here in this post?
          So 3 questions
          1. Should I even use the memory?
          2. If yes, which settings to use including voltage, with these restrictions in mind?
          3. If yes, what does it "mean" performance-wise (or otherwise) running this memory on these non-optimal settings?
          Thanks again
            5-5-5-15 is fine, performance just not as good as 4
            Not a big deal at all, so give it a shot, as long as the system is stable you're good to go
