I have: ASUS Crosshair V Formula-Z AM3+ AMD 990FX + SB950
which states DDR3 2400(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066
In process of ordering: AMD FX-9590 Vishera 8-Core 4.7GHz Socket AM3+ 220W Desktop Processor - Black Edition FD9590FHHKWOF
on AMD memory chart for FX processor located on their website; if the available motherboard slots is 4 then it doesn't matter if 2 or 4 of the slots are populated, the highest memory speed supported is 1600
However elsewhere I am reading: Integrated DRAM Controller with AMD Memory Optimizer Technology •Supports up to DDR3-1866
Am I correct in thinking that: G.SKILL Trident X Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C8Q-32GTX
would be a good choice if I wanted to plug and go for now and do a little overclocking later on?
Is their any way to use the 2400(o.c) with this processor and would I really see that much performance gain. Planning on using system for gaming and 3-D plotting/printing
