Heat Spreader Removal
  • Heat Spreader Removal
    Hey everyone just want some advise on how to remove the heat spreaders on my two new sets of G.Skill DDR4 F4-3000C15Q-16GRR. I am removing them to watercool the RAM with EKWB equipment. I was able to remove one side easily with a little blast of heat from a heat gun. But that only worked on the side with the memory chips. The other side has no chips and has a thicker thermal pad which appears to be really on there good. Any idea's??
    more heat, that's the only way to loosen up the adhesive.
      Well thank you for the reply I will give it another go with more heat! I will give an update.
