Can't get 4x4gb sniper series to run at 1866
  • Can't get 4x4gb sniper series to run at 1866
    Purchased two sets of these: http://www.newegg.com/Product/Produc...82E16820231460 (total of 16gb) and can't get them to run at 1866 with my Gigabyte GA-990FXA-UD3 motherboard and AMD FX 8350. I tried enabling XMP in the BIOS and windows will not boot. It defaults to 1600 with no problems. Otherwise, It seems no matter what I do I get BSOD's...Please help!
    XMP will not work because it is designed for one set.
    Manually input the basic memory settings, DRAM Frequency, timings, and Voltage.
    Raise CPU-NB Voltage +0.1V
    Make sure each kit is installed in the same color slots. Test and see how that works and report back.
      What are the basic memory settings for this set up? I think that's half my problem..thanks for the response, BTW.
        The settings on the RAM. Those are the values that need to be input.
          I know what settings are. I meant the actual settings ( like what to set them at).
            These sticks won't run at 1866 in a 4 module set up...
              Yes, the actual settings are listed on the RAM.
              DDR3-1866 9-10-9-28 1.50V
              If they don't work in a 4 module set up, try raising the DRAM Voltage to 1.60V to see if that helps. If not, lower the DRAM Frequency to DDR3-1600, timings 9-9-9-24, and see if that works. Keep me posted on the result.
                How can I tell how fast my ram is currently running after the settings are changed?
                  You mean like in Windows? CPU-Z, Aida64, HWInfo32/64...
                    Excellent. Thank you. I'll try this again and give an update.
