hi
I have buy this keyboard a few month ago, G.Skill Riplaws KM780 RGB and see keyboard have last version of firmware installed. I download and install last version of software/Driver for this keyboard.
I create profiles and Macros well with no problems and change leds colours and etc with also no problems. But if i try for export my changes after a fews seconds software crash and i need to reboot my pc for use it again. If i try for import files also software after a certain time also crash again.
I see after this import certain Macros not work and i need change macros not working in keys for default key and after need enter new macro again.
If crashs more others times keyboard stop working and i need descobbect and connect again from usb port keyboard for he work...... Needed also restore all default setting of keyboard and do again all configurations.
Import or export are crashed all times, certain times work others not work and crash.
Any ideia for fix this?
I have Windows 10 pro Build 1803 version.
