I purchased all the parts from NewEgg on 05/15/2012. I initially installed OPENSUSE 12.1 and i experienced intermittent freezing with absolutely no response to keyboard / mouse. After about 10 minutes it would power off. I am not an experienced linux person so after about 2 ~ 3 weeks of trying to resolve the issue I decided to go back to Windows 7 Ultimate x64. I am seeing the same issues in Windows. Today I updated the bios from version 1.20 to 1.60 and then attempted to run memtest86. It ran for over an hour with no errors and i let it continue. When i came back 3 hours later the power was off. I restarted memtest86 and again it ran for over an hour with zero errors, however when i checked again after 30 or 40 minutes it had powered off again.
Tonight I tried to run Prime95 and the computer froze within 10 minutes. I did see that someone had a similar problem and was able to run stable without XMP at 1333. The person later was able to test with another pair of the same memory from a friend with stock settings and it was stable.
I'll repeat that process and see if i can run stable at 1333. Then the next question is if that doesn't work, I would assume that i need to test each memory stick individually in different motherboard slots, correct ?
Sincerly
Chuck Haatvedt
here are the critical errors from the last 7 days from event viewer. I did not change any of the BIOS setting when I assembled the computer. All of the bios setting are stock. I always run my systems at stock settings and have not done any overclocking.
there were 8 of these, all with exactly the same text other than the date / time.
Sincerly
Chuck Haatvedt
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 6/22/2012 4:28:17 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: i5-3570
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2012-06-22T21:28:17.474810500Z" />
<EventRecordID>9499</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>i5-3570</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: i5-3570
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
