I have had a 120 GB Phoenix Pro SSD for many months. I had it in a system with an ASUS P8Z68-V Pro MB and a 2600K processor running at 4.5GHz. I check the speed using Otto on this system after doing the Parted Magic trick to restore it's performance. The drive was not set up as the boot drive. I have since moved it to a system with an old ASUS P5BDeluxe MB running an E5800 Processor at 3.2 GHz. The drive is set up to be the Boot Drive on this system. I used Acronis to copy/clone the boot partition from a 500GB hard drive. The partition is aligned properly per Paragon's PAT Tool. The results from running Otto were a little disappointing. As an example the 0.5 Read/Write results went from 16726/20505 to 11491/7749 and the 8192 results went from 273355/280790 to 261632/252052. Does the MB/Processor effect the Otto results or do I need to do the Parted Magic trick yet again and then restore the partition instead of cloning it using Acronis
2010?
I'm not 100% sure but I suspect the BIOS was in IDE mode when I ran the benchmark. After I went in and changed the BIOS to AHCI mode the system would not boot - it hung in the BIOS during AHCI identification process. Either I have a screwed up SSD drive or the OLD P5BDeluxe BIOS (1238) does not like SSD drives in AHCI mode?!
2010?
