Hello there.
I'm posting here to find out what, if anything, can be done regarding my G.Skill Falcon 128GB SSD - whether I can repair/mitigate any wear, whether replacement is an option, and if neither are possible, whether G.Skill operates a recycling program so I can dispose of it safely.
I'll explain the basic details of what has happened.
Approximately 2 months ago, my system started experiencing odd problems. Applications that I had used just hours before had stopped functioning, apparently after nothing more than a reboot. Assuming it was just OS deterioration, I reinstalled my operating system after performing an ATA secure erase of the drive (to restore any lost performance), and that seemed to be the end of my issues.
However, a week ago the same thing happened again. This time the issue was different, but similar - Windows Explorer would no longer launch, but I could still have marginal use from my pc by running utilities via task manager and the command prompt, so I was able to back up my own data and go through the steps again.
Finally, it happened again yesterday. Initially the system would launch then hang upon login. After two restarts, the system would then bluescreen before the Windows login screen would appear.
I can no longer reinstall the operating system on the drive. It fails after a varied amount of time - sometimes within a few moments, sometimes after the first restart - but it always fails, either with a bluescreen or by having the Windows Setup tell me my media or drive is corrupt and that I should run CHKDSK.
I know my installation media (I install windows 7 from a read-only USB drive) is not corrupt, as I had to use it to reinstall onto my hard disk to get my machine back up and running. I have not made any hardware changes since the problems started happening - My last hardware change was my GPU more than 8 months ago.
So basically, my questions again:
1. Do you think this damage is repairable, and if so, how?
2. If not repairable, is replacement an option?
3. If neither of these is the case, does G.Skill operate a recycling program so I can dispose of my drive safely.
Thanks.
Thanks.
