Hi Gskill, my falcon II has been acting weird lately. After a few BSOD's from windows 7, the last restart caused this message to appear
http://www.windows-noob.com/forums/u...1224623227.jpg
However, when I enter BIOS, the Falcon II is still detected, I switched boot devices priority from Falcon to my secondary data harddrive which is a Seagate 500gb, and funnily enough, windows booted fine (my pc is still loading the OS files properly off falcon II)
So I decided to start fresh again with the SSD by reinstalling windows 7 from scratch. Then on BIOS I placed the SSD as first boot device again and the error message pops up again, but if I put it on second place and first device being my normal HDD, everything loads up fine... assuming if I'd only use the SSD and no other drives I can never get it to boot even though I have installed Windows on it,
Is this a common error or a hardware fault? I am hoping I could fix this myself by wiping out the SSD or reflashing the firmware, please help!
At the moment everything still works as long as I use a secondary drive as primary and the BIOS will automatically boot up windows from the SSD...
