I recently bought GSkill Phoenix Pro 120GB SSD that I wanted to install into my Mid 2010 macbook pro
I'm having problems getting it detected by macbook pro when its instlalled into the HDD space.
Here is what I did:
1) Connected SSD via USB to SATA adapter. It got detected by OSX and I was able to use superduper to clone my 250GB HDD to SSD
2) shutdown macbook pro and swapped HDD for SSD.
3) after my macbook pro powered on, it keeps sitting at grey screen without apple logo. It looks like its not detecting the SSD at all
So I decided to try using external hard drive as a go between.
I superdupered my internal HDD to external HDD and installed SSD again.
Upon booting i got the grey screen again and was able to boot only by doing Option+Command+Shift+Delete to boot of external HDD
I also tried PRAM zap with same result
Any ideas of what might be the problem and how to fix it? SSD seems to be working because I was able to see it via sata to usb adapter
SSD I have is:
GSkill Phoenix Pro 120GB Model: FM-25S2S-120GBP2
Any help is greatly appreciated
Here is what I did:
SSD I have is:
