Mac systems: how to upgrade to firmware 2030?
  • Mac systems: how to upgrade to firmware 2030?
    Hi GSkill Team,
    I'd like to upgrade to the latest firmware my Falcon I 128GB
    The unit is the main disk of a Macbook Pro
    Am running a version of Mac OsX 10.6.4
    How can i do a safe firmware upgrade?? your instruction aren't made for Mac Users (as usual)
    Hi fastboy
    I am really sorry.
    because the firmware is be made from manufacturer.
    the only way I can figure out is upgrade on X86 PC system .
    then install in your MAC.
    please back up your data.
      Thank you for your reply.
      From what you told me, I understand that a firmware upgrade is actually NOT possible, for the following reason:
      - The only way to install windows on a mac is through bootcamp (under OSX) which creates a NTFS partition than is used for the installation of Windows. Your instructions are saying to use a bootable USB stick BUT Mac hardware doesn't allow to boot from a USB device...and even if it would allow that, the firmware upgrade probably couldn't be done cause it would see 2 partitions (1 MAC and 1 Windows) and the upgrade would not continue.
      So in short, there's no way to upgrade to a new firmware if your hard disk is installed in a Mac.
      Sad
        sorry mate
        I can't provide you any help.
        I have no idea how to solve your problem.
        I ask somenoe more professional than me.
        he told me even MAC can boot from USB and upgrade on dos mode.
        they frame are the same.
        I don't know does it work because we don't have MAC.
        maybe you can try
