2030 Firmware Changes
  • 2030 Firmware Changes
    What are the changes or additions to this new firmware? I have 3 Falcons running in Raid0 and would like to know what is new before I flash them.
    I have updated the change notes.
    Please check it again.
      I have flashed 2 of the drives but the third one says Firmware download failed. All three drives had firware 1916 before flashing to 2030. Checked cables and sata settings and still no go.
        What model name is that faild one?
        Falcon or Falcon II? and what is its capacity?
        If you could post the faild screen shot, i could analyse the issue faster.
          It is a Falcon FM-25S2S-64GBF1. Sorry I did not take a screen shot and I am not allowed to post attachments. The error message is the same as #5 in your download thread.
            Hi Griffyj,
            There are two files for 64GB, have you tried each one?
              Yes I tried both files. One file does not find any drives.
                Originally posted by vaca View Post
                Hi Griffyj,
                Tried both files. 64GB-2 see's the drives but comes back with the error. 64GB-1 does not see the drives. Any ideas or should the drive be RMAed.
                  I had some problems with my update too. I had to change sata cables connections to find my SSD in the update tool.
                    anyone notice any performance improvements or speed increases after flashing to 2030?
                      Be sure to set SATA to IDE mode before update and your SSD installed in the correct port.
                      Griffyj, could you tell me your motherboard model name? i want to verify that if it's an incompatible issue?
                      SirPingsAlot, do you mean that you change the SATA port you installed your SSD and finally you could update succesfully?
                        Yes, Falcon 128GB was not listed in the FW update tool, so I connected it to another SATA port . Sometimes I`m not able to find the SSD when I do changes in my system with Asus P6X58D-E motheboard (latest BIOS).
                        When this happens I change Sata ports until it recognize the disk.
                        It was lot of problems to find the disk when I installed XP in ACHI mode.
                        Best regard
                          [QUOTE=vaca;28035]Be sure to set SATA to IDE mode before update and your SSD installed in the correct port.
                          The Motherboard is a Asus Maximus Formula. I have not tried moving to a different sata port yet as I have not had time to try and flash it again.
                            Griffy, have you noticed any speed increases or any other performance improvements with 2030 versus 1916?
                              I have not benched the system since flashing the other raid drivess because one of them will not flash. The system does not seem to be any faster or slower.
