Got a technical problem?
Thank you!
See more
See less
Keystroke not working
  • Keystroke not working
    Hello. I'm facing a very weird problem with my keyboard, KM780 RGB. 5 of my keys (s, e, d, c, 3 ) just randomly stops working and they go back to normal randomly. There is no fixed event for it to stop working or going back to normal. When the issue is occurring, I tried reconnecting the keyboard to my PC. I also tried connecting it to my laptop. The issue still persists even then.
    A: SW-2.03 FW-76
    A: Issue occurred much later after the 1809 update. But it didn't happen immediately.
    A: KM780 RGB, NA English
    A: Win 10 Education 64-Bit, Version 1809
    A: USB3.0 in motherboard back panel
    A: Asus H97 Pro Gamer
    A: Nothing but windows defender
    A: None
