Hi all, hoping someone has seen this or is running the same combination.
Setup:
- Kit: Trident Z5 Neo RGB 64GB (2x32GB) DDR5-6000 CL30, F5-6000J3036G32GX2-TZ5NRW
- CPU: Ryzen 9 9950X3D2 Dual Edition
- Board: ASUS ROG Strix X870E-A Gaming WiFi7 Neo (kit is on the QVL for this board)
- BIOS: tested V1002, the previous version, and the latest (AGESA 1.3.0.1d)
What happens:
- Each DIMM POSTs and runs on its own in A2, including with EXPO II.
- Neither DIMM POSTs on its own in B2.
- No two-DIMM configuration POSTs (A2+B2, A1+B1, positions swapped) at any speed, including 4800 JEDEC stock. It sits on the DRAM LED for the full 15-minute training window.
Already tried:
- Multiple CMOS clears, reseating DIMMs, CPU reseat, cooler pressure check
- VSOC 1.25V, VDDIO/MC 1.40V, VDDP 0.90V, VDDG CCD 900mV / IOD 1000mV, DRAM VDD/VDDQ 1.40V
- UCLK=MEMCLK, Memory Context Restore disabled
- Setting EXPO on one DIMM first, then adding the second
For what it's worth, this kit ran as a pair on a GIGABYTE X870E AORUS Master X3D ICE with a regular 9950X3D, though that system had memory-related BSODs and a Karhu error at stock.
Questions:
1. Is anyone running this kit (or another 2x32GB kit) in dual-DIMM on a 9950X3D2? What board and BIOS?
2. Has anyone seen a single DIMM work in A2 but not B2 like this, and what turned out to be the cause?
Any input appreciated. Thanks!
Setup:
What happens:
Already tried:
Questions:
