Hi!
I built a new gaming PC and these are its specs:
When I look at the motherboard it jumps from CPU LED to DRAM LED a couple of times and then it gets stuck on the DRAM which indicated that there's a problem with the RAM.
The weird thing is: The RAM sticks work individually fine. As long as there's only 1 RAM stick connected, the PC boots normally.
No matter what configuration I place the RAM sticks in, it never works when there are 2 connected simultaneously.
Tests I've done:
I'd appreciate some help with this issue.
Thank you!
- Motherboard: Gigabyte Z490 VISION G (1.x)
- RAM Sticks: F4-2666C18D-16GTZR (Trident-Z-RGBDDR4-2666MHz-CL18-18-18-43-1.20V16GB-(2x8GB))
- CPU: Intel Core i5 10500
Tests I've done:
- Checked each RAM Stick individually - Loads normally.
- Checked each RAM Slot individually - Loads normally.
- Using DDR4-A1 and DDR4-B1 - Doesn't work.
- Using DDR4-A1 and DDR4-B2 - Doesn't work.
- Using DDR4-A2 and DDR4-B2 - Doesn't work.
- Using DDR4-A2 and DDR4-B1 - Doesn't work.
Thank you!
